- Dec 4, 2011
- 242
ALCON,
Help me GMTNation, you're my only hope. I've been searching for days and finally am at the point of needing specific answers.
Problem 1: Calculated ~2-3 MPG lower than it used to be. It is now approx 13/17.5, conservative driver, never speed. Noticed an average of under 18MPG on a 1200 mile road trip recently, mostly 65MPH driving - the same road trip a year ago averaged 21MPG.
Problem 2: I get a quick "Low Oil Pressure" message on the DIC after start up. It only stays on a few seconds and never comes back on the rest of the time the vehicle is running. This doesn't occur every startup, and it isn't consistent to only cold starts, only hot starts, or any other causality I can discern. The oil pressure gauge itself ranges between 50% and 65% or so from startup throughout regular driving (assuming 50% is straight up), forgive me for not remembering the actual units of measurement or hash marks on there. The oil itself is filled fairly high on the dipstick, right about at the top of the proper fill range.
Problem 3: I feel like it has an inconsistent idle; I watched it in Torque, it ranged from 590-660. Every now and then it will do a stumble then surge but this is rare.
Vehicle: '05 TB LT, 4.2L, almost 100K miles, good Michelin Latitude Tour tires, no codes reported in Torque Pro
Background: I've stayed on top of the maintenance since I got the truck at 36k in 2008. New plugs (correct Delcos), removed and cleaned throttle body, plus all the fluids (trans, diff, transfer case, brake, etc), new air filter (Wix) completed last summer at approximately 92k. The issues I'm seeing weren't happening then, they mostly started within the last few months, best I can tell. I also do a bottle of Techron when I think about it. Last one was 3-4K ago. The gas on base is certainly not top-tier quality, so I'm sure that's not helping. Current oil status on DIC reads 40%, but it's in the neighborhood of 5 months/5k old.
I have noticed the upstream O2 seems a bit lazy - mostly ~1Hz variations, but there will be sporadic periods of .25-.5Hz. Ranges from .1-.8 or so. Downstream is pretty flat around .7.
What I've done so far: Ran a bottle of Redline through the last tank. Spent some time looking into it and seemed worth a try. Changed the CPAS and Cam Sensor today; left the battery unhooked for 1 hour or so. No reason to believe they were bad, and even after removal they both looked fine (no oil in connectors, clean screens), but given the 100k milestone it seemed like a good idea to swap them out anyway. Both correct ones from GMPartsEast. It appears something of this lot helped the idle. More like a 615-630 variation now. MPG remains unchanged. I saw on another post about testing the lockup by gently pressing on the brakes while cruising on the highway - the RPMs went up a couple hundred by doing that, which the post seemed to indicate meant it was working correctly.
What I'm going to do: I bought a Delco O2 sensor but was unable to remove the old one. Going to take it to a local mechanic to have him break the old one out for me on Monday. I'm also going to have him do an oil change as I'm about due based on the 5k old oil. Additionally, that will help exclude the oil as a potential cause of the Low Oil Pressure warning.
My actual questions for you all: Is there something else I should have the mechanic do on Monday, or have him specifically check? Is there something I can look at with Torque Pro that will help identify the issue(s)? Is there anything else I should do, check, or replace? Does a 'Low Oil Pressure' warning for a few seconds after startup really mean something is wrong if it doesn't ever come back and the oil pressure gauge looks fine?
Should I do a SeaFoam treatment? If so, is there a good how-to on the process for Seafoam - I've seen that people use it in the vacuum booster or something like that, but I'm not sure how to do this; detailed explanation and pictures would be very helpful.
Hopefully you all can give me some advice. We're about to move to San Antonio and will be doing a very long drive over the course of 10 days (including some Disneyland days) and regaining 3 more MPG that I used to have would be awesome, but I'm more concerned about some problem escalating and stranding us somewhere in the desert.
Please let me know if you have any clarifying questions or can offer any solutions. Thank you for your time in reading my tome. Apologies for the length, but I wanted to give you any and all requisite information.
Cheers,
LT
Cheers,
LT
