- Aug 15, 2015
- 10
Hey gang! I have an '06 Saab 9-7x with the 5.3 V8, and 88K miles. Recently I've noticed a shudder coming from the rear driver's side tire. It does not bind or crow hop, it's just a shudder. It occurs when normally accelerating from a stop turning almost any degree. I changed my encoder motor 7 months ago, a gear inside had broken causing it to bind up, which made the driveline bind up and crow hop on full lock turns. I've removed the encoder motor completely, didn't notice a difference, but I'll have to recheck that this week, I'll update. Yesterday I changed the rear diff fluid using Mobil 1 synthetic LS 75w/90. Afterwards I drove in figure 8's and donuts. I can still feel a shudder.
Here's some more driveline info. 7 months & 7K miles ago when the encoder motor broke, the front diff. inner seal started to leak. I drained and removed the front diff. from the oil pan enough to pry the old inner seal out and press the new seal in. I replaced both seals (genuine GM), intermediate shaft and axle disconnect (genuine AAM) just as preventative maintenance since I had everything apart. Of course I had to refill the front diff, but decided to change the rear too. I used Mobil 1 Synth LS 75w/90. However - at that time I added the GM Limited Slip additive to the rear diff. because it was "recommended" by the parts counter guys. I've replaced the transfer case fluid using AutoTrakII about 15K ago.
In searching the forum for help, someone had posted a GM bulletin saying the G86 did not need the LS additive. Does anyone know if this shudder could be caused by this additive being used in conjunction with the Mobil 1 fluid? Too much LS friction modifier?
Thanks again gang! I appreciate it!
