- Jul 11, 2013
- 81
For those of you that have helped in the past, thank you.
I now have some more info ...
1) rear diff fluid was NOT changed as the seller said they did (which also means they didn't put in the additive) - I had this done today
2) transfer case fluid was changed 2 weeks ago ... fluid looked good, didn't need to be changed
3) discovered that the transfer case has in fact been opened at some point in recent history (bolts have evidence of being removed and there is silicon around the seam of the transfer case)
The problem I was having with the rear end still happens: turn the steering to half or more, either in forward or reverse, and the inside rear wheel grabs.
New diagnosis today: with the truck on the hoist, transmission in neutral, if you turn one of the rear wheels, all 4 wheels turn ...
Thoughts?
Thoughts?
