S3customs trailblazer build
S3customs
27
S3customs
27
Start of the door pods...
I have sanded the edges down to match all of the lines on the door but dont have pics of that yet
- - - Updated - - -
Started putting the baffles together and getting the positioned on the doors.
put in all the bolts to hold the panel on and ca glues them in place
S3customs
27
Little bit more done tonight. Finished bracing the baffle and put some duraglas in some areas that i thought might be prone to warping or pulling up. Hopefully i will get these wrapped and glassed tomorrow. any comments or questions are always welcome..
I got both panels wrapped and ready for glassing. Going to refoil the door panels and attach the panels and glass them on the truck to make sure i get no warping or lifting of the edges.
Layed down a layer of foil then attatched the panel to the door and put it back on the truck to glass.
S3customs
27
Its been a slow ride but im finally at a point i can get back on my vehical instead of always working on other peoples.
still waiting on two more amps that are on back order and should be here by months end.
S3customs
27
Got more of the bracing done. also doubled up the baffle. was a little tricky the way i did it but think it was worth the extra effort to have it overlap and interlock like it does. Also resin in 6 proggresivly larger layers of heavy chop mat in all the joints.
All comments and questions are appreciated..
STLtrailbSS
HOLY SH*T That is amazing man I can not wait to see this thing finished!
How many batteries are you planning to run?
S3customs
27
Got some more done. Resined the complete inside of the box and duraglassed any joints that needed.
Then resined the complete outside of the box and nocked the baffled down and filled and sanded preparing it for paint.
Wired the box
I painted the baffle and wasnt really happy with it so i covered it in burgandy ( exterior vehical color) suede. Also put a coat of cheep spray paint on the rest of the box even though it wont be seen after trim panels are done.
Got the box bolted down this morning. Used four pieces of angle iron and four grade eight bolts. Dont think its going anywhere. Took pictures of one side other side is the same.
After a little setback ( had to unbolt and pull the box back out because it wasnt sitting flush with the floor because of the speaker wires were zip tied in a bundle instead of laying flat) Got back to the start of building the front trim.
S3customs
27
This is what i came up with at the last min to be able to run multiple speaker wires into the door and to get rid of the stupid molex plug in the jam. I got four door boots from mid 90s ford ranger and used rubber cement to bond them together and to bond the smaller ends of the ford boots into the factory trailblazer boot ends.
I cut the boots long and over lapped them by about two inches and cut the trailblazer boots so the ford ones would sit inside Then i extended the door side plug wires and put the plug on the inside of the kick panel. There was pleanty of room for the nine factory wires along with four pair 16 ga speaker wires .
I just noticed the body side boot is not pushed in all the way. Also a couple pics of the slow progress on the front trim panels of the box.
S3customs
27
Resined and then laid three layers of heavy chop mat. Started amp rack as that cured.
Come on guys give me some feedback on this.
Small update. Finished the layers of matting and pulled the panels. now to start cleaning them up and body working them. Also little more routing on the amp trim panel.
S3customs
27
Have been body working the panels. Not alot of pictures because everyone has seen duraglass and rage filler being sanded lol. Got some more done on the battery box and amp rack .
Sorry for the slow updates just been blocking body filler for a few days now. decided to change the amp rack and to eliminate one of the four channel amps. It was an extra amp that wasn't going to be used at this time, just put in there for possible expansion down the road.
S3customs
27
Been busy with customers cars and have had little time to work on my truck . Few small up dates . nothing to excited but its all coming together.
starting to come together
Huge thanks to Mark Mc from trailvoy.com and offroadtb.com for all the help with my lift. Needed to get tires so i figured might as well do it right. Today i ordered 6 inches of lift and all new struts and shocks along with new ball joints. And 18 inch kmc rockstars with 34x11.5 nitto trail grapplers.
S3customs
27
update
Just got lift done and rims on just have to put the bumper covers back on..
- - - Updated - - -
Finally done...
and its officially not just a mall crawler..( yankee lake truck night)
S3customs
27
Thank you. Its all done. there is four batteries total.
jimmyjam
looks like i'm not the only one who takes forever to finish projects... just that mine aren't anywhere near that awesome when i'm done :frown: congrats on getting that all buttoned up :thumbsup:
TexazReece
I say HOTT Damn now.that's what I.call a HELL OF A AUDIO UPGRADE :cool::thumbsup: kudos bro. I feel sorry for those that sit in the back........naw no I don't :rotfl:
I will say as I have before...Incredible Build. Well Done!
million-miles
189
WHY. Because you can. So your getting about 5 mpg now. Very nice and quality build
I cant see how he would get less than double digits....
cmatb08
101
that is amazing! that trumps what i have planned!!! keep us posted on what kind of numbers you put up
Boricua SS
3,080
amazing work and awesome build man..one of the best setups ive seen :tiphat::thumbsup:
Porkins
6,960
Nice craftsmanship, just to a fan of extreme audio.
S3customs
27
Thank you for all the great comments. Im getting between 10 and 11 mpg around town and it has 3.73 gears as of now. IM still running the stock alternator , it has been doing a pretty good job so far. It takes a few min of beating on it at an idle for it to drop off of 14 volts. I have been holding off putting a bigger one in because there is a motor and axle swap in the near future (hint.. no more buying of spark plugs lol )
S3customs
27
Sweet build :thumbsup:. How many miles on the LT?[/QUOTe
140k First owner was a good friend of mine that i new maintained it very well and so did i. Timing chain cover has a small oil leak besides that its a 100%.I wouldn't hesitate to drive it across country.
dmanns67
32,979
I agree. I am right around 120,000 miles and still drives just as good as when I bought her with 15,000 miles.
