rust dots and oxidation
06envoydenali
52
whats up guys just washed the truck today after a rough winter (only got one hand wash in) and there is oxidation and rust dots all over the hood and doors, any ideas on what products are the best to use and the ones to stay away from? I dont think i need anything to abrasive but i dont know all that much about oxidation or rust residue. :confused: thanks:thumbsup:
fletch09
1,982
believe the red dots are called "rail dust"
i have it on my white TB every year. also got it on my other 2 white vehicles i prev. owned.
suggest clay bar application to get rid of them. followed by a good wax job.
that may help your oxidation issue also.
harmless
2,049
What he said.
The rust dots are partially the result of a shitty clear coat application that traps particles within it. These particles rust over time and end up as these little rust spots you are talking about.
Wash throuroughly. Clay bar the whole ride and seal the deal with a good polymer based, clear coat safe wax. :thumbsup:
OR
You can always get a new paint job (to replace the shitty one). :crazy:
TheBad
I agree, Claybar will remove the oxidation as well as the rail dust (rust dots).
The technique I use is:
1) Wash thoroughly.
2) Claybar vehicle.
3) Compound any trouble spots.
4) Polish back to high shine.
5) Wax to protect shine.
Cable810
690
I have sorta the same issue, just in certian Aeras. Will have to do the Claybar!
Boricua SS
3,080
we were just talking about this at the midwest meet yesturday...
claybar is your best friend... love the outcome... takes a long time.. but well worth it..
Claybar is awesome, even a relatively quickie job helps tremendously. For example I clayed my Camaro on Saturday, one swipe down the top edge of the door and the clay was brown! When I finished the paint felt so much smoother, almost like glass.
Just make sure to keep the surface wet and lubricated :yes: Most kits come with a spray detailer you can use, but I've always run out before the clay is used up. Maybe I use too much spray. Anyway, some car soap mixed with water in a spray bottle works fine too.
I definitely need to get mine cleaned up.
06envoydenali
52
thanks for all the feed back, lately when i use clay, no matter how much spray wax i apply the clay color rubs off on the paint. It may be that the clay was old but when i opened the a new sealed package it did the same thing. Do you thing clay goes bad even in it original seal pack. I bought a 3 pack of clay about a year and a halve ago, you think it went bad?
No it shouldn't. Mine was older too but was fine. I used Meguiars.
Did you thoroughly wash the car first, then knead the clay until it was softer?
Black_tb
817
not trying to steal ones tread but i have little white looking cracks in the hood looks like it gets too hot or something you think maybe the clay bar would help get rid of that also ??
SBUBandit
597
I didn't have a clay bar when I bought the TB, and it had spots all over it. I used Meguiar's Paint Cleaner and some elbow grease and they all came out. Then I waxed it with Meguiar's Tech Wax. Just the Tech wax every once in a while since, but 3 years later the spots never came back, and it spends 7 days a week parked less than 100 yards from a very busy railroad track (The source of rail dust). Mine just needs a good polish now
06envoydenali
52
I washed it and polished it with swirl-scratch remover, knead the clay and it still left yellow clay on the hood. the only other logical reason i can think of is that the hood was still to hot from sitting in the sun all day?:confused:
Yellow? Hm the clay I used was white.
It does need to be a cool surface. I did mine in the evening after dinner.
