I'm hoping someone can help me. My 2002 TB started having RPM spikes 4500-5000 and would get stuck at that level. I couldn't hit the gas to accelerate further but it didn't lose or surge in power and I was able to decelerate to a full stop to get the RPM to go back down. This started happening in the 20-25 mph range first, stop and go, parking lots etc. No codes whatsoever.
Changed tranny fluid/filter/gasket Ran fine around town, getting it to 55, no problem. Got on the FW, hit 65, RPM shot up got stuck again and limped home keeping it under 40mph every time it spiked had to pull over. This time it threw a Torque Converter Clutch Solenoid stock open or failed code. Replaced that.
Checked the throttle body, looked like it had been cleaned recently (bought the truck around 6 months ago) and thought they may have damaged it so I replaced that while gasket was curing. (disconnected battery while doing this)
Another code came up for #5 coil pack so I replaced that along with all spark plugs.
Did the relearn sequence.
Now, sounds better than when we got it, runs smooth but the RPM spikes still spikes. The difference is that I can still accelerate and I can feel the gear change (no thumping, rocking or grinding). If I'm doing 55 it'll shoot up to 4000 and stay there for a few seconds before wiggling and coming down.
When this happens there is no spinning in sand sensation, no grinding/thumping and when we dropped the tranny pan there were no shards.
I'm at a loss as to where to look and any advice would be appreciated. Thank you!
