- Jul 27, 2013
- 57
I've been searching through this awesome site for weeks trying to get to the bottom of my rough idling and vibration through the steering column in my 2004 Envoy 4.2 and have tried a number of things already and am still having issues. I must be overlooking some things. The Envoy has 145,000 and I've kept up with the maintenance on it over the years. If anyone has any more ideas on what to do next I'd greatly appreciate it. Here's the list of things already taken care of in the last couple of weeks:
- replaced the throttle body (new OEM part not a rebuilt part)
- replaced the MAP and air temp sensor
- changed the spark plugs (AC Delco 41-103)
- replaced all 6 coils after 3 went bad
- did the Seafoam in the brake vacuum line (twice) and in the gas tank
- replaced the fuel filter
- reset the PCM by disconnecting the battery for over 30 minutes after the TB replacement and again after the new spark plugs
- had the engine mounts replaced but they weren't the OEM part
- took it to the dealer to see if the PCM needed an update and they told me no - they told me to replace the transmission mount
- no codes or CEL ever
- replaced the upstream O2 sensor
- replaced the alternator a couple of months ago when it went bad
- just replaced the tensioner pulley and serpentine belt when the pulley started to go
The symptoms are kinda similar to others I've read but a little different too. Without the AC on it runs smooth and seemingly perfect. As soon as I turn on the AC the rough idle starts and so does the vibration but its only noticeable when in gear and stopped. When the car is still "cold" the idle RPMs run at about 700 but after the car gets to temp the idle (in gear and at stopped at a light) seems to drop to 500 but waffles a bit to 650 then back to 550. The lower the RPMs go the worse the vibration gets.
So I need help (in more ways then one but that's for a different forum!) trying to figure what I've overlooked. I've read a lot about the camshaft actuator solenoid and I guess that's the next thing to try? I'd love any and all thoughts or ideas. Thanks, Jim.
