Right side low raiding suspension
Elsewhere
1
New York
A week ago I changed the height sensor of the suspension since the vehicle was lying on the right side, after that change it was normal for a few hours but now I am lying down again and does not activate the compressor
northcreek
3,320
WNY
Well if you've ruled out a leaking bag or lines, I would suspect that your compressor unit is in need of replacement.
Did you adjust the sensor properly?
This is such a failure prone and expensive system we usually just recommend to replace the air bags with springs.
Reactions: TollKeeper
8,053
I agree with @Mooseman here. Although the air ride is nice, and gives a more supple ride, it just has so many problems, and its never really fixed even when working. Its not a matter of if, but when, it will break. Put some springs in it, and call it a day.
jvest
