NEED HELP Replacing A/C clutch bearing??
deerslayer1985
148
I have a 2002 Chevy Trailblazer ltz with the 4.2 I6. I have been hearing a whining noise for quite awhile now. I took the idler pulley off, and it was fine. I finally narrowed it to the a/c. When I take the belt off the noise stops. It also gets quieter when the a/c is on. So it is obviously the a/c clutch bearing. Is that replaceable without evacuating the a/c and having to recharge it? I was thinking about tryng to fix it myself if it doesn't need to be evacuated and charged. Thanks for any help.
littleblazer
9,265
As much as I don't like linking to the OS there is a good writeup on this. Pull the shroud etc. You'll need to rent a pully puller. clutch bearing how to.
The pn is MT2031 from autozone for the bearing iirc.
MEHMET ONUR
