- Aug 25, 2012
- 955
Hey all, I got myself into another big pinch. I have a 2013 Kawasaki Ultra300LX jet ski and went to change my oil but stupid me put the oil filter on with the socket and wrench so now I can't break the oil filter loose.
I tried with the socket and ratchet I used the first time to install it and it slipped off the filter and now it has a little dent on the keyed part of the filter.
I had tried to put some intertube between the filter socket and the filter and turn it off but because of where the filter is positioned in the hull I couldn't get a good pull or hammer to pound on the socket to the filter.
I tried to take a big pair of pliers and put them as far back near the oil cooler as I could and break it loose but failed with that too. It just crushed the can a good amount.
Just last night I went and sprayed some PB blaster on the little area between the filter and oil cooler in hopes of maybe soaking up the rubber gasket to make it slip but I doubt it will help any.
My question is this: do you have any other ideas on what I can do to get the damn oil filter off? I don't want to go straight to the screw driver method because I know that will just cut the can open into pieces and not bust it loose. I purchased oil filter pliers from snap on that are curved and have teeth to bite the can and hope to get it loose with that and if it doesn't I will then try to use a rubber cap you find in plumbing at the hardware store, clamp that on and try to pry it loose with a pair of pliers. If that fails then I will use the screw driver method to attempt and pry the can open and I bought a special tool that has 3 fingers that go inside the oil filter where the drainback holes are and hope to god I can spin it off that way. Otherwise if that fails, I am going to have to do about 3 hours of work to take the intake manifold off (which it is a supercharged engine so it is a lot of work to get it out) and get a screw driver and a hammer to bang the top of the filter from the oil cooler. If I had room, I'd use the screw driver to bang it off from the side but there is barely enough room for me to get a hammer in there, let alone to swing it and have enough force to beat it loose.
Any tips or help would be much appreciated guys!
