There are hidden snaps. Once you get it out it will be obvious. I know, that's not a useful advice. Not certain anybody's taken pictures, but here's the factory description:
Disengage the closeout trim cover (2) from the upper trim cover (1) in the following order:
5.1. Stand in front of the column from the drivers point of view.
5.2. On the left side, gently pull downwards on the left side of the closeout trim cover to loosen 1 snap. Do NOT fully remove the closeout trim cover.
5.3. On the right side, gently pull downwards on the right side of the closeout trim cover to loosen 1 snap. Do NOT fully remove the closeout trim cover.
5.4. Starting from the left side of the trim covers, gently roll the closeout trim cover to the right to disengage the remaining 4 snaps.
Important: You must inspect for 2 pan head tapping screws (2) in the lower trim cover (1) before removal.
If necessary, remove the 2 pan head tapping screws (2) from the lower trim cover (1).
Gently unsnap the lower trim cover from the upper trim cover.
If equipped, disconnect the electrical connector from the power switch.
Remove the lower trim cover.
Unclip the power pedal switch from the lower cover.
Important: You must inspect for 1 TORX® head screw (3) in the upper trim cover (1) before removal.
If necessary, remove 1 TORX® head screw (3) from the upper trim cover (1) and the closeout trim cover (2) for removal.
If no screw is present, remove the upper trim cover (1) with the closeout trim cover (2).
