About six months ago I asked for your guys' help removing the front strut to replace motor mounts.
https://gmtnation.com/forums/threads/motor-mount-replacement-issues.17012/#post-533796
Well.. I'm at it again. A friend's Envoy has the same symptoms I did, and since I had done it once I offered to do it for my friend.
This strut is EXTREMELY stubborn. Been at it for hours trying to get the lower strut yoke from the lower control arm. I have tried:
1) a puller (it broke on the first try - it was the exact same model I successfully rented before)
2) a pickle fork, hammering on it with a sledge hammer
3) the pickle fork stuck in there, prying on it for leverage, while hammering the stud (nut attached) with a sledge
(This whole time I have been soaking it with penetrating oil for a couple days)
I reallly don't want to take apart the whole strut (pinch bolt on the top of the yoke, sway bar, upper control arm pinch bolt for upper ball joint, etc)...
Any suggestions?
I'm thinking of jacking up the wheel/hub assembly at the lower control arm, to see if I can get the strut compressed in such a way to get that pesky middle bracket bolt out. Then return it to normal position and get the other two. Is this a bad idea?
Any suggestions?
