Removing factory exhaust
4,659
. can it be removed by removin can it be removed by removing the shocks and lowering the rear axle enough. I found a donor vehicle and I want to remove it as a whole unit.
fletch09
1,982
IIRC, if you disconnect shocks the rear end should drop enough to get it out.
there will alot of manuvering.
suggest you get it up on a rack if possible. :twocents:
4,659
OK, the yard can place it on a lift, the bolts at the cat could be a pita but looks like it will slide out over the axle.
Yasha
