Hi All,
I recently bought a 2006 GMC Yukon XL. Pretty much as soon as I got it home it started throwing p0172 and p0175 codes, which I've learned (for a flex fuel vehicle) can often mean the ethanol reading is off. So, at the very least, I'm looking for something that will read the ethanol % to see if that's the case, and maybe even something to reset it so I don't have to go to a dealer.
I'll also just state that I'm pretty cheap, and don't want to spend $4000 or whatever for a new mechanic quality tool, there's just no way I can justify it. So, I'm looking at various levels of budget tools, and obviously the more I spend the more functionality I would expect. I'd be interested to hear opinions/recommendations on what I'm thinking.
First up is the plain cheap BAFX scan tool you can find on Amazon. I actually already purchased this, but couldn't get an ethanol % reading using it and Torque. I'm going to play around with custom PIDs a bit more but I'm not holding out a ton of hope. I'm still in the return period, and even if I wasn't it cost $16 and does way more than my code reader from 15 years ago, so not too big a deal if it doesn't work out.
Next up is the OBDLink MX+. Supposedly it reads way more than the BAFX, including proprietary GM stuff. But, it's also $100, as opposed to $16. Are the extra capabilities of the MX+ worth the much higher price tag?
Finally is a Tech2 clone. At this point you can find them for under $300, which isn't nothing, but if it saves me 2 trips to the dealer it's paid for itself. This is appealing because I'd be able to reset the ethanol % myself, not just read it (right?).
As an added twist, I also own a 2008 Pontiac Vibe. If I could use the Tech2 clone on both the Yukon and the Vibe then it would be worth twice as much to me. But, the Vibe is really a Toyota Matrix, so will it work with a Tech2? And, will a single Tech2 clone work with both a Yukon and a Vibe? I've seen it mentioned in some listings that the clone only works with "cars" and not "trucks." Does the Yukon count as a truck in this sense? Is there maybe just a different software card required?
As you can probably tell I'm pretty new to all of this, the last car I spent a lot of time working on was a 1979 Jeep Cherokee, no computer issues there Anyway, I'd greatly appreciate any opinions and/or advice you can give me. Thanks in advance!
