MY QUESTION: Why is the low pressure side (Blue Gauge) reading in RETARD? I know that is the gauge max to not damage the gauge, but why is it so high after evacuating and refilling? How much would too much refrigerant be to cause extremely low side high pressure? Maybe 2 to 3 oz? I would appreciate any help.
1st Attempt
2006 GMC Envoy SLE 4.2l - 200k+ miles
Interior Fan blows hard
Vehicle was running with a/c on and doors open when gauges were read
1st Attempt
- A/C was working, but only getting down to about 59-60°
- Checked Pressure with a DIY recharge Kit (AC PRO)
- I set the arrow on the ambient temp (80°)
- It was in the Green, but not in the Red “V” section.
- So, I began to add a 12oz can of R134a and as I was adding, the gauge went up just slightly, almost so it didn’t appear to move.
- I noticed no change in a/c temp in vehicle
- Purchased a Harbor Freight Vacuum pump and Gauge Set
- Hooked up the gauge to read and the low side was in “Retard” meaning pressure was too high. (I’m thinking because of the 12oz can I added in my first attempt)
- I began to evacuate the system which pulled both gauges down to 0.
- This took about 10 minutes to evacuate
- I left the air compressor sucking for 20 to 25 minutes after it reached 0.
- It never went below 0
- My Vehicle is supposed to use 1.9lbs of r134a
- I did not have an attachment for the refrigerant can to gook to the yellow intake on the Gauges, so I disconnected it to use the a/c pro gauge
- I began to add the first can with the vehicle NOT running and it took about 8oz.
- I then started the vehicle and resumed filling with refrigerant. I continued until I felt I had put in the necessary 30.4 ounces…. Which should have been just over 2.5 cans.
- The gauge went up to the original reading that I had in step 1, and didn’t go over that spot (which was in the lower side of the green)
- The air is cooling down to 49° with the rpm’s up to 1k to 1.5k, goes down to 54-57 at 500 rmp (IDLE)
