- Dec 4, 2011
- 568
I picked up one of those recharge kits with the gauge that adjusts based on air temperature. This weekend it was about 95F outside, so I had the dial spun all the way up. That puts 45-50psi right in the center of the 'ideal' range for recharging.
So I rolled down my windows, cranked the AC to max fan, and put in about 3/4 of the bottle. Every time I let go of the trigger, the gauge dropped back to 43psi. So how do I tell when the system is fully charged? Am I just seeing the standard pressure on the back side of the pump and this is an indication that my system was nearly empty? Should I keep adding more coolant unti I see an actual rise in the pressure reading?
The coolant I added did make a noticable difference -- the air blowing out is actually cooling down the truck again, although I don't think it's still quite as cold as it used to be. I don't want to put in too much coolant and over-charge the system, but at the same time I would expect the pressure to change at some point indicating I am actually fully chraged... What should I do?
