The passenger side rear defrost wire is loose, it has a small metal plate attached. It looks like it was once soldered to the metal plate affixed to the rear window. I know that I cannot solder (with heat) because of the glass, what if I create a " cold solder" connection, heating the metal plate on the end of the wire and place that on the metal plate on the window. I would first clean and apply flux. What do you think????
