- Dec 8, 2011
- 9
My friend accidentally put my rear driver window down on my vehicle the other night. When we parked and turned the key off the window just went down before we opened the door. So after getting the window up. The last 2 days i've figured out that when i turn the vehicle on the window goes down automatically. Once i drive until my doors lock i can reach back and put the window up with the switch on the door and it will stay for about 30 min then maybe randomly go down. If i try to put the window up with the switch by me it'll go up a bit then stop maybe go down then stop and go up a bit (all while i'm pulling on the switch to put the window up). I also noticed the switch is very loose so maybe one of my friends pulled on it too far and broke something. I'm assuming it's the switch or a loose wire inside. Window lock doesn't do anything to keep it up. Is there a fuse for that window or the rear 2 windows that i can pull to kill power to the system? I may try to unplug the motor so that i don't have to keep dealing with it during the winter. I tried searching if this has happened before with no luck.
