04 Rainier 5.3 with 250k. Bought at 170K and had to replace the rear bags because they would leak down over night.
Everything has been flawless for the last 80k miles until this weekend when i went to hook up a utility trailer to haul some furniture and it was really low, almost on the bumpstops.
Didn't think anything of it but it refused to air up. Checked the compressor by hitting the button to turn on the inflator and it worked like normal.
What causes the pump to turn on but not pump the bags up? The bags hold air great, but when loaded down it would not inflate.
I disconnected the level sensors from the control arms, set them to the "full bottom" position with the car running and it didn't air up.
I checked both level sensors on either side and they were intact connected to the control arms. I read online somewhere they are 75-100 ohm sensors and they both ohm at 89-90 ohms and do nothing when I move the arm. I assumed I had bad sensors.
I went to the salvage yard today and found 3 rainier/bravadas and ohm tested 3 sensors and they also ohmed at 89-91 ohms, no movement when I actuate the arm. I assume my sensors are OK and that ohm data I read is wrong and they operate on some other function.
I searched the forum and can't find anyone with the same issue. Any idea where to start?
I have bilstien air-spec rear shocks which are like a year old on the back and I really like the airbag setup so I'd prefer to get the system back alive.
Thoughts?
Thoughts?
