- Oct 29, 2014
- 2
Vehicle: 2003 Trailblazer 2WD 4.2L LTZ (not EXT) 188,000 miles
Task: Replacing rack and pinion with rebuilt rack because of leaking seal at the nut under the steering gear input shaft. Leak has slowly increased over past five months, and Lucas leak oil has not worked.
Question 1: Do I need to remove the lower control arm bracket (LCAB) or JUST the bolts?
The Hayes manual states remove the lower control arm bolts and refers to another section involving the COMPLETE removal of the lower control arm bracket. I have researched this forum and others forums about the rack and pinion, and no one said anything about the LCAB bolts or removal of the LCAB.
I will greatly appreciate any tips or tricks, and lessons learned to include pictures or videos about the process.
