NEED HELP Question?🤔
Bronsonc1856
6
71730
I've got a 03 TB the is 2wd and bout a used motor assembly online and this new one came with the 4x4 shyt on there.. so can u use that in my 2wd frame ? Like can I just bolt it up like normal or no?
The oil pans are all the same. Your 2wd has the same pan as the 4x4 minus the front diff and disconnect. If you look from either side of your wheels where the front axles would normally be, you will see the hole in the pan. If the replacement engine came with them, just take them off.
One thing to be certain, 08-09 engines WILL NOT work in your truck. Different crank trigger is not compatible.
Bronsonc1856
6
71730
Can I just throw it in there and bolt up as normal?
New motor is out of a 2003 TB
Only differences is new one is got all the 4x4 shyt on there . I'm not understanding what your saying lol dumb that down me for please sir
Reactions: Eric04
Yes
If there's 4x4 shyt on it that your 2wd don't have, take it off. It's just bolted to the pan. I don't know how much dumber I can make that, LOL!
Mektek
656
FL
Remove the front differential - you don't need it. Or just leave it alone and it will not cause you any trouble.
MissCrutcher
