I wired up Ascender tails on my Envoy using the attached pic (unknown author) I found floating around. This setup makes the top light (red LED 3157 bulb) on the fixture work as a parking light & brake light. The middle light becomes the turn signal ( red LED 3157 bulb) and I don't have the bottom bulb wired into my reverse lights yet.
What I want in the end is the top two bulbs to work as parking/brake/ turn signals. Is that possible? I think I have the correct bulbs installed to make that happen but I have no idea how to change the wiring to accomplish it. Also, I noticed the middle bulb socket only has 3 wires and 3 pins but the top socket has four wires and 4 pins. I'm thinking I need to change the middle socket to the same type as the top to pull this off, correct?
