Put in CAI need help.
kjkim93
696
So I installed a Volant CAI. But when I took the MAF out I forgot which way it was installed from factory. And with the pictures online it doesn't help. Is it gray clipside up? Or silver side up?
There should be an arrow on it showing airflow direction. If not, then the screened side is towards the air filter.
AWD V8
463
If you can't find the direction of air flow arrow you have a 50/50 chance of installing it correctly. If you get it the wrong way around it will idle poor, and be undrivable when you raise the RPM. No harm done, just remove and turn it around.
kjkim93
696
Thats the thing. so if its wrong it would def affect driving performance? Its been fine, with LimeSwaps tune and the Volant. Its fun to drive again. But its been bugging me since I had no clue if I put it back correctly.
Not really. The screen is to protect the thin sensor wires in the sensor. It works by heating the wires and measuring how much voltage it takes to keep it at a certain temperature. Doesn't matter which way the air flows for that but the screen does protect those wires from possible debris.
AWD V8
463
Apparently their is an arrow next to the plug connector. Top right in the photo.
Or is yours like this one?
kjkim93
696
I have be top one. So is the arrow facing towards the filter or towards the throttle body.
AWD V8
463
The arrow shows the direction of air flow, from the air filter to the engine, the arrow points towards the engine.
timmerk
