Here's the deal. The metal power steering line on the drivers side sprung a leak.
My plan is to cut the line (s), use some brake line and double flare the fittings, if I can. I figure the double flare is used on brake lines that work under approximately the same pressures.
I'm hoping this is a viable solution, don't think I can get the whole line assembly installed in the garage, too tight, and working on the truck outside isn't an option (townhouse, the association is REAL pissy about working on a vehicle).
Anyone think this is going to work?
