Project "CODERED"
Code Red
Guess I'll copy my build thread over here ;-)
2004 ZQ8 3.5 Auto Colorado Crewcab
All stock
Street Scene Roll Pan added
Street Scene Gen 1 Bumper added
Trucktec Soft Bed Cover added
Bowtie changed from gold to black
Goodmark 2 inch Cowl Hood added
Xenon Side Skirts added
Street Scene Fog Lights added
factory flares were removed for the time being due to the side skirts
Truck all painted up
Added AEM intake
Added Magnaflow exhaust
Installed clear corner headlight and parking/turnsignal lights
audio install
JL Stealth Box I got for half the cost of new and a amp I had laying around
installed Street Scene Stainless Grill
American Racing RTS 20's
Drop number 1
Belltech 2inch Ball Joint Drop
Belltech 3inch Leaf Spring Drop
My friend Josh helping out
has a little bit of a rake
Drop Number 2
well with the first setup I was rubbing like crazy on bumps
So I switched the factory ZQ8 springs out with Belltech 1inch drop springs so I went back up 1/2 inch in the front
Painted front caliper setup 2 tone
Added the factory flares back on after trimming them down
Added door jab trim pieces from an 07 model
Street Scene Spoiler
Hellwig Traction Springs
Installed all red 3rd brake light and TYC LED tails
Added my flush bed cover and the street scene spoiler
New stainless steel gauges also modified the needles to red
bed cover and spoiler painted
Other parts
Clean cut creations crossmember still needs to be installed
Drop Number 3
Belltech Coilover setup for the front Also have a set of 1 inch blocks for the rear that I havent put on yet
pics from the coil over install
well got them on the passenger strut gave me issues when taking it out.
friend compressing the next one for me
always needed when working
picked up a set of 18 inch factory colorado xtreme wheels for the winter timeand track
painted the wheels flat black
then finally got my center caps
Also added Street Scene mirrors
changes here
repainted the wheels passenger side charcol with a red lip and drivers side added a red lip was trying to decide which I prefered
also painted the mirrors and added a black chrome grill
Picked up a set of Silverado SS wheels
had a friend bore them out
test fitted ;-)
added rubber :-D
got some new tires bought them used with 1k-1500 miles on them for $300
old 245/35/20
new 255/35/20
old currently on the wheels
new against old
New stacked up till I decide to swap them on
thought I'd finally update this thing
So awhile back I picked up a canyon shell from Paul that he already cut out
Also picked up a SS grill for it
I got the grill and my bumper as well as the colorado grills powder coated
meanwhile I was gettign the bumper fixed and repainted and getting the grill shell painted also
pieces all painted
installed
hmmm what Did I pick up??
L33 5.3 V8 Out of a 06 Silverado. Has 22k miles on it. All aluminum block and heads
the bad parts
need a new pulley no biggie
smashed oil filter umm ok
oh the damn cracked oil pan (they only took 50 bucks off for that grrr)
took the engine to the engine shop
went to check on it
then brought it back home
and before I left for israel I blew a tire
However bad news I did hit something and it shot a hole through my inner fender and dented the bedside from inside :cry:
Picked up some new tires
LH8 oil pan for the V8
Painted behind my grill
I'll have a few other items coming when I get back from Israel
One thing I need to fix when I get back is my exhaust
hmm whats this?
Started stripping the motor down
Still need to paint the heads, valve covers, brackets, water pump, pulleys, etc....
Not sure how I'll do the fast intake
Swapped out the oil pickup since I have to use a LH8 oil pan (colorado/canyon/h3) since the silverado one won't work, and the oil pickup was too long so I had to use a LH8 one. However I did get a new windage tray but I saw no need to swap it out.
LH8 pan, it will be staying the cast aluminum color
and another reason why I can't use the pan
Small update
;-). Need to have them stripped welds cleaned up and then recoated
and thats how everything pretty much sits, haven't had much time to work on the truck lately due to traveling with work and now trying to get my garage ready for winter and issues i've had with my Jimmy.
Damn you went a long way with the car! Great job with it though! I LOVE the black chrome :yes::yes: I am thinking of it for my truck now!!
It was like i was reading a story. Nice truck man,you got it lookin sick
Talk about "Picture Heavy" I thought my laptop was having a seizure. Nice SS rims!
I do what I can lol
jimmyjam said:
thats whats up. is that fast intake gonna fit in there?
i had a red trailblazer on black wheels, everyone loved it. i had blacked out the grill and cross bar as well, something to think about
Thanks the truck the intake came off of was a Colorado ;-)
If you noticed I swapped the Chevy grill for a GMC grille
smitty5150 said:
I am in love with your truck!
I've been toying with the idea of dropping a v8 in my tb for over a year now. Everyone says it isn't worth it, but I still want to try.
Thanks. Oh this will be worth it for the swap
To the OP, AWESOME! Great to see the transformations your truck has seen, the many stages my 02 TB has been through are mostly in memory as Im too lazy to get pics usually. Its been stock, dropped, raked (stock rear, dropped front), stock, and now has a 3/2" lift on it.
You have an 02 right...Ive got the PCM issues sorted out Im 95% sure. Run a LS1B 1MB PCM with a factory 02/03 TrailBlazer 5.3L V8 Operating System. Remember they're the same truck, just a few inches longer. GM's done the hard part by writing us an Op. Sys. that will still communicate correctly with the cluster, BCM, etc. :cool:
Figured it was time to update this
Washed the wheels up
Layed out
Masked up
started coating
Love the hood!
Love it! What did you use for paint?
Whats your cam lift? Is that all you upgraded was valve springs?
I got a cam, rod, and springs. A friend was going to put this package in his and then he decided to not do his v8 swap. I still havent put the cam package in yet, but hopefully soon.
Cam -
Intake valve lift - .580, degrees of duration 225
Exhaust valve lift - .590, degrees of duration 229
Lobe center 114 + 4 LSA
Push rods -
5/16" x 7.400" hardened
Valve Springs-
Gold Dual Valve Springs, Super 7 Locks, Ti retainers, Seals & .505" Bases (use with stock guides)
jamlynnk007
