Problem ! Error code
Ghost
932
P0172 - GMTypePowertrain - Fuel and Air Metering - ISO/SAE ControlledDescriptionFuel Trim System Rich ConditionsLocationBank 1CauseEngine running at steady speed in closed loop, IAT sensor input from 14-158°F, BARO input over 75 kPa, fuel tank level over 25% and the PCM detected the LONGFT value was over -30% for 5 seconds, or the SHRTFT value was over -20% for 45 seconds
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
How many miles on the vehicle? What were you doing when it happened? Any maintenance done recently that may be related?
Ghost
932
I was working on my air intake yesterday and forgot to put that sensor back that has two wires on it....drove 70+ miles to work and realised I forgot to put it back and it was hanging next to the exhaust manifold. So its safe to assume that sensor is bad ???? Does anyone have a part #? My gf truck broke down Thursday so I'm stuck driving her to work....-(
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
Are you talking about the one on top of the intake? IF so that is the MAP sensor.
Ghost
932
This one View attachment 29430
I forgot to put it back in the rubber hole thing and it was just laying next to the exhaust....surprised it didn't melt ????
Did an eBay and autozone search and cat find anything that looks like this.
Ghost
932
That is your air temp sensor.
Is that my problem ?....or
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
That is what you posted a photo of... And if it is running rich that could be the cause of it. Have you tried putting it back in and clearing the code?
Ghost
932
Yea, cleared code and truck still runs rich and high idle. :-( becides the bad MPG and high idle can the vehicle get damaged if I drive it ? I ordered the part online from Los Angeles , I am in Ventura so it should be here hopefully by Tuesday.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
I think you should be okay. I ran for a few days waiting for coil packs to come in. It ran like crap until I got things replaced.
Ghost
932
Haha that's funny. I could just see it now putting along...chug chug chug. Alright. Probably going to just rent a jalopy till the part comes in...I think its time for new spark plugs and coils while I'm at it. Just hit 55k mi this week. Thanks for the help buddy.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
Don't bother with the plugs if you are only at 55K. If they are still the stock plugs you should be fine to 100K.
Ghost
932
Went to wallmart today, noticed the engine light went off and the truck is running fine now. Weird......is there a way I can reset the ecm without removing the battery terminal ??? Isn't there a fuse under the engine bay I can pop out for 5 min ?
dmanns67
32,979
Ohio
Did you mean PCM? I know you can pull fuse #10 and fuse #28 for about 15 min to do a reset instead of unhooking the battery. I usually take this route after cleaning the throttle body.
Here is a list of fuses I found that BlckShdw posted a while back for the 4.2L I6.
Ghost
932
Just for fun going to leave #10 & #28 out for 20min±
All this b******t for this
I am sick of the LOUD intake sound when going up our canejo grade. Checked three times to make sure everything is in its place before I start the engine.
The airbox is hollowed out for my 9" AEM pro-dry filter.
I wouldn't bother replacing coils... Those don't need replaced unless they fail. I have original coils on mine at 181k.
Ghost
932
All went well TB is back to purring like a new born kitten ! Thanks yall
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
and what all did you do to resolve it? So other know for the future...
Ghost
932
Well since my du'mass forgot to put the MAFS or MAP sensor in the air intake pipe the exhaust manifold nuked it so I replaced it....that's it.
djthumper
Administrator
Nov 20, 2011
14,956
North Las Vegas
Glad to hear. Too bad the rest of this was a result of it.
Ghost
932
I may have some slight gain loss but I can tell you our grade is 9% incline and the TB would BOG down up the grade plus 120db± noise ! But I am happy with the much quieter intake. I def won't be going back to stock.
Ghost
932
I'm curious after running the engine like this if it was hard on anything...like the plugs, fuel rail, fuel injectors etc etc
Swale
