Here is a curiosity. I saw this in the Upull yard on a 2005 Trailblazer EXT, 5.3 M engine.
This joins fuses #22 and #55 together. #22 is IGN E powered directly by ignition switch terminal C in RUN and START. #55 is the O2A fuse powered by the powertrain relay which in turn is controlled by the PCM.
I am wondering if they had a powertrain relay issue or were they bypassing a fault in the fuseblock base like a cracked solid copper wire/trace?
Also noted a battery to body ground wire that was only hand-tight and by the looks of the terminal eyelet at least appeared to have been not making any contact for some time.
I had thought about taking the ECM and TCM to add to my collection of test subjects but decided to leave them as someone may want that engine and related controllers.
