Power Window problems
ChriSS K
243
Glad to be with the crew again. To be honest when I first started getting the PM's to relocate I thought it was some type of scam, but one of the PM's I got was a name I recongnized... Either way thanks for putting this together guys!
Here is whats going on. The two front windows don't go down with the auto down switch. If I press it once for them to go down like they should they only go down 1/4" and a time. This is the same for both sides even if I do them one at a time. Also I noticed that they are SUPER slow to go up and down...even to the point that they stop even with me holding the button down for them to go up. Once in a while they will work like they should with the auto, but few and far between. The back windows work great and go up and down quickly. It almost seems like the fronts motors are too weak to work correctly. Is anyone aware of a problem/solution to this problem? Thanks
Sounds a lot like the old "high friction in the regulator" problem. Purely mechanical. Ebay has replacements.
ChriSS K
243
Can always count on the roadie! Thanks
Boricua SS
3,080
hey buddy.. i see you got my email... welcome aboard :tiphat:... and already, its paying off for you :raspberry:
but yes, i agree with roadie.. time to start looking on ebay...
fadyasha
1,134
Yup I just replaced both rear regulators last month. I could point you to a guy on ebay that sells them for a good price. Just let me know.:thumbsup:
ChriSS K
243
Thx. Except my PMs look like scams? :confused:
Not intended to be. I didn't receive mine from you roadie. One of the members that 1st sent it to me had a low post count and was just asking for my email??? I know now it was harmless, but at first look....
Russ
43
Maybe this will help:
Install/Replace Broken Power Regulator
[video=youtube;47tAE7mCx1g]http://www.youtube.com/watch?v=47tAE7mCx1g[/video]
Russ
Russ
43
Replaced my drivers door regulator (same problem as ChriSS K) still same problem. Goes down great, coming up it stops 1/4 way up and stops. Switch? If so, why only coming up?
Thanks
Russ
fadyasha
1,134
Thanks
Russ
That's strange! Was the replacement used or new? Try bringing up the window with the door panel off. Will give you a better insight on what's going on.
Russ
43
Checked the window operation with the door panel off and everything looks ok. Nothing seems to be binding. The regulator was new. So, now I know the old one was good also.
How would I go about checking the switch? If it is the switch, can I buy just the single switch or will I have to buy the whole thing for $200.00? :eek:
Thanks
Russ
Boricua SS
3,080
Thanks
Russ
by you saying everything "looks" ok..did you test the window as well... im sure what fadyasha was trying to get at was maybe the door panal is whats keeping the window from coming up.. does the window work regularly with the door panel off.. or does it do the same thing?
and you can get a switch off of ebay for usually $100 or lower... check out seller 1933trader.. his store specializes in tb's/voy's
Russ
43
Yes, I did test the window with the panel off. Again, it only went up a few inches and stopped. I then had to push up on the window manually while holding the button.
I'll check out 1933trader.
The only thing I haven't done is switch the drivers side with the passengers side.
Thanks
Russ
Boricua SS
3,080
Thanks
Russ
ah ok.. makes more sense now... i would definetly try switching modules before you commit to purchasing a new switch... im subscribed to this thread to see the outcome as a friend of mine is experriencing this same problem
Russ
43
Ok....
I just went out and switched the modules. No change!!!!!!!!
I did start the car and it seemed to have made a difference with it running. Not as good as before the change but better.
Maybe it's time for the Big 3?
Waiting to see if it gets better with use......
Russ
Russ
43
On the way to work this morning, stopped for coffe, put the window down and very very very slow coming up.
What now? Anyone????
Thanks
Russ
10,685
If you try rolling the window up at night (when your modules are lit up) do the interior lights dim at all, like they do when the window is all the way up/down and you hold the button down? If that was the case, I might try checking the window channel and seeing if anything is obstructing the window from going up on it's own without you having to push it. :twocents:
Russ
43
This morning, warmer than the last few days and no problem with the window.
Noticed that the original regulator started acting up once the weather got cold.
So, it seems as if the colder it gets, the worse it is.
Still electrical?
I am stumped!
Russ
I'll check it this weekend when I can get it in the garage.
Russ
10,685
Still electrical?
I am stumped!
Russ
Yeah, still electrical. Sounds like a grounding (or contact) issue. When the weather is colder, the metal contracts, and wherever this contact spot is, is losing some of it's connection. When it warms up, the metal expands and makes a good enough connection to roll the window all the way up.
You could have a damaged wire somewhere (likely in the rubber boot passing between the door and cabin) or possibly the harness that plugs into the regulator. I would start from inside the door and work inwards. :twocents:
Russ
43
Thanks, at least now I have a starting point.
Appreciate all the help! :biggrin:
Russ
91RS
When it's acting up, can you put your hand on the glass and help it up while pressing the switch? The window weatherstrip could have some funny wear the glass is getting caught on and the motor doesn't have another power to move past it. I've seen this before on a Venture van.
Russ
43
When it's cold, that's almost what I have to do. After I changed the regulator, I actually had to reach in the door (had the door panel off)and push up the window.
I'll start with the grounds and wiring and look at anything that might hinder the operation.
With help from everyone on here, we'll figure it out!!!!!!!:thumbsup:
Russ
ChriSS K
243
Thanks
Russ
Update...
What your seeing is exactly what mine was doing. I took it to the dealer and they replaced both regulators and the auto switch panel on the drivers side all under my extended warranty!!!
fadyasha
1,134
ChriSS K said:
Update...
Great for you Chris! Glad it all worked out for you! Russ your next :tongue:
ChriSS K
243
Thanks. I'm saying I would recheck those regulators because it sounds like what I had...
Russ
43
Chris,
Glad you have your problem taken care of. :thumbsup:
Gonna check everything this weekend. I can put it in the garage and take my time.
Thanks, we'll get this!!!!! :crazy:
Russ
fadyasha
1,134
I hear you. I suggested the same earlier, and yes I was facing the same both my rear doors. One day they just went down and never went up. It happened within 3 days of each other. :hissyfit:
snowbear
54
We've noticed our '08 has been doing this recently. As usual, the folks here are quick to come up with some solutions.
Thanks, all.
06_4.2_4x4_ls
