- Oct 25, 2012
- 126
I have a power steering system question. I have a small leak in my 05 TrailBlazer 4.2 power steering system. I need to get it on a lift to get a better look, but it seems to be coming from where the lines go into the rack. I am aware that there is an o ring or 2 where it goes in. However that is not my question. What I am wondering is if there should be pressure on the system itself or not? That is, should I have an audible release of air pressure when I open the full cap on the fluid reservoir right after shutting the vehicle off after being up to operating temp? I assume there is a pressure regulator of some sort in the pump to control the output on the high pressure side but I wasn’t sure if the reservoir seals the system or if it should be somehow vented. Thanks for the help.
