Power steering line replacement (TB 03)
JimShoe
16
Hey there,
Has anyone replaced the high pressure power steering line? Have run into problems at the rack and pinion connection. If you've replaced yours, do you have any tips or sites that give you some direction? Appreciate any help. It's getting the O-rings out that is the problem. I got 1 out and am working on the 2nd using a tool that I made using a metal dental tool and a piece of plastic conduit. You can see the top hole through a hole in a bracket but have to use a mirror for the bottom. I have done a fair amount of mechanical work but this job has been like a dream (a bad one).
:confused:
Yasha
