- Jun 21, 2014
- 43
Hey y'all!
About 2 weeks ago leaving work, the SES light began flashing and engine was running really rough. You could physically feel the car shaking while at the red light. After a few minutes it stopped. I yok the code reader to it when I got home, and no codes. No problems with it for about a week. A few days ago, same problem arose when I went to leave work again, except this time it lasted the entire drive home. Got a solid (not flashing) SES light. Code reader said a P0300 and P0301 code. At 160k miles I decided to spring the extra money for 6 new coils.
So, fast forward to tonight when I went to install. Now, keep in mind I had replaced the plugs about 30k ago with the 41-103's. Pic #1 is the plug from #1. Number 2 plug had a decent amount of oil in it, as did #3 and 4. Note, I did NOT remove all the spark plugs, just #1 and2 spark plugs. I did replace all 6 coils though. The remaining pictures are on the exhaust-side of the engine block, where I suspect I have a bad/worn valve cover gasket. Can you guys take a look and see if you agree? Also, does that plug look like normal wear for roughly 30k on it? Thanks!!!
