- Dec 4, 2011
- 597
1. I'm going to be putting my new exhaust manifold on soon, its a Dorman OE replacement one. The casting is rough around the ports and I was thinking about getting a dremel and smoothing them out. Would it hurt to port these out a bit to open it up, or would that cause compression losses?
2. Also, my current exhaust setup is OE cat converter, 2.75" piping to a 2.5" inlet/outlet flomaster muffler, and then 2.75" OE piping to the rear hanger and (the tip fell off) so that's where it stops.
3. My muffler has a dent in it and is pretty rusty/rattles around, and I was thinking about just straight piping it from the cat (Ideas for a good high flow cat?) and all the way out the back with a stainless tip. Would this work out well? I would have to test out the sound to determine whether or not I liked it.
My current setup is probably due for an entire replacement by now anyway, so I'm looking for an inexpensive solution but something that will last the rest of my truck's lifetime. Thoughts, ideas? I don't mind being a semi-guinea pig for this one.
