Hi
I'm wondering about how much the PCM can be modified when flashing. I've read that codes for the fan can be removed so that a regular fan can be installed but I've got a slightly more complicated scenario.
When I tow, I get P0495 codes, Fan exceeded 1600RPM for 81 seconds. It only happens if the engine RPM has been over 1800RPM for 120 seconds and the PCM commands 0 percent duty cycle from the cooling fan. I get these when I go up a steep grade in 2nd or first towing the trailer, the engine revs high and the fan spins too fast and by the time I've reached the top I've got a CEL.
The P0495 code doesn't invoke limp mode or affect power/efficiency of the vehicle but it does mean that I wouldn't notice if there was a second code because the CEL is already lit.
@Limquat - can the parameters be changed? Could the 1800RPM be changed to 2400RPM or could the 81 seconds be changed to 300 seconds? I don't know how far you can go when you reprogram, is it this granular or is it just an ability to disable the code from turning on the CEL?
JayArr
JayArr
