PCM SWAP question
McGMT
621
ConeKilrAutoX said:
I have an 04 4.2 envoy and I am swapping in a P12 from an 06 TB.
:undecided: Will the 04 BCM and the 06 PCM be friends? or do I need replace the 04 BCM? :confused:
thanks
I don't think that is do-able between those two years because of some modifications done in 06 and I believe the TCM is not integrated in 04 like it was in 06...
Could be wrong and if I am someone will tell ya in a lil bit haha...
ScarabEpic22
728
This is another area Ive struggled with over the years with this swap, it *should* play nice, but no guarantees. That said, for the I6 the PCM controlled the engine and trans until 08 when GM switched to the E67/T42 combo. V8s only had a PCM for 03-04, starting in 05 they used an ECM/T42 combo.
That said, where did you get your 06 engine harness from? The only ones I can find on eBay are stupid expensive.
ConeKilrAutoX
1,179
thats some good news. I got my harness from stricker brothers junk yard in ohio. got them down to 125 shipped because he had to cut the blue pcm connecter (with a foot of wiring) off of another 06 trailblazer harness since the other one was damaged. it IS the whole engine harness, I have been matching things up today just to get a feel for everything. it was from a 06 TB 4.2
chirobo1
