I have a 2005 GMC Evnoy SLT, left windows down a little during heavy rain and now passenger window isn't working properly. It is currently all the way up, but wont go down when pressing the switch down, the switch itself clicks, not the motor or anything. Does this also from the driver side controls. When pressing the switch up it makes sound as if it will go up but cant because it is already up not the same as going down.
So I bought a new motor plugged it up to the switch and confirmed my suspicions the motor would go up but nothing when I pressed down, so problem wasn't the motor obviously. I then decided to order a switch off ebay it was the exact same part number and matched perfectly, but had the same problem so I guess the switch wasnt the issue. I've checked all fuses and relays they seem to be fine and every other window works just fine. Also the locks and mirror on the passenger side door work perfectly its just the window thats the problem.
Not sure where to look now, help please.
