Jeez, now you went and done it! Link?Whoever did it will have 7 years bad luck.
Are you sure you didn't do this yourself just to have the excuse for the turn signals?
You know you can replace just the glass don't ya?
PnP yards are scarce around here. I'll check around.On my '02 TB, I retrofitted the original mirrors and tapped into the harness going into the door modules. Was a PITA to pass the wires through. This one I had found an actual pair with the signals in the PNP yard. I have since fitted the TB and Saab with Silverado extendable towing mirrors with signals which required cutting off Silvy connectors and solder in the TB's.
They're starting to get plentiful in PNP yards now. You could probably find a set.
