Parking Lights not turning on?!?!?
Cable810
690
I took out the inner wheel wells weeks ago and I finally got around to getting them back in. Getting them in required that I take the Grille, and Headlight assembly to get the front bumper cover off. Make sense? Days after I got it all back together I noticed that the parking lights arn't comeing on when I turn them on. I checked the bulbs and they seem to be ok. They work when I use my indicatior just dunno why they wont come on when I turn them on. I havn't checked the fuse as I don't know what one.
Thoughts?
Cable810
690
Yes when I use my indicator they(Parking Lights) flash like they are suppose to. They wont come one when I turn them on.
Cable810
690
Maybe a Video will help this???
10,665
Do your parking lights in the rear come on? Have you checked for any blown fuses? (they're listed in your owners manual, and also inside the fuse block cover panels)
Cable810
690
When I took the Video the taillights were removed. I'm working on the rear bumper so thats why they arn't there. I have no clue what fuse, I checked the rear Fuse box cover and it says 30 for park lt Can't figure out which one though. With the Taillights in that only fixed the hyper flashin. They still wont come on. I'm thinking its the fuse, not the lights for obvious reasons.
What I just read on TV Same issue but even if I move the light dial all the way to the right the parking lights arn't comeing on :hissyfit:
Talking to my dad he suggested that it might be a 2 way bulb?
MAY03LT
Delmarva
Still need to know if the parking lights in the rear are working.
Cable810
690
Let me grab a Quick video, be up in 15
10,665
A yes/no would be good enough. If they aren't, then I'd suspect your parking light relay has gone bad. Not sure if any of the others in the fuse block are the same, that you could swap with it though.
Cable810
690
The top bulbs light up on the Tail Lights when I turn the parking lights on. This help?
MAY03LT
Delmarva
Absolutely. The switch, relay, and bcm control were all ruled out with that one answer. So I would check the F-Park fuse in the rear fuse block next.
Cable810
690
F-Park would be Front Parking Lights Fuse 37?
Cable810
690
The fuse is still good?? Ya'll sure its not a 2 way bulb?
10,665
Did you check the fuse by eye sight, or with a meter/fuse tester? The front parking lights ARE 2 filament bulbs, that's why the turn signals work, while the parking lights don't.
Cable810
690
Checked it via Eye Sight. Mayebe the other fillament is bad. I'll take a look
10,665
That's not always a reliable way to go. Do you have a meter, or access to one? You're going to need it for troubleshooting purposes. You'll need to check some of the different parking light fuse sockets to see which one(s) is not getting a signal when the lights are on, to better determine where the problem is.
Cable810
690
Don't have one/access to one :sadcry: I'll do some askin
Cable810
690
the fillaments were bad. Some new bulbs and I should be good to go. If not I'll let ya know!! Thanks for ya'lls help
MAY03LT
Delmarva
All 4 front parking bulbs are/were bad?
