- Jul 24, 2012
- 822
So I took the back wheels off to try to figure out the parking brake. Ended up with a new passenger side caliper (the inboard pad was toast and the outboard pad was like new, I figured the piston was stuck -- it would explain the brake noise coming from that wheel as well) new pads and rotors on the back, and a fluid flush. Well, half a fluid flush, I will do the front maybe tomorrow.
Anyway the new brakes are awesome BUT I still don't get much bite on the parking brake.
Did I not dial them up tight enough? Maybe I was worried about them dragging and they could have been tighter.
The driver's side brake shoe was super tight when I first took it off. When I went to put the new rotor back on it wouldn't go on, even when I dialed it in all the way. There was a little tic-tac shaped spacer between the two pieces that receive the shoe, I took it out and I was at least able to get the rotor on.
What even happens back there when I pull on the lever?
Anyway, still a little confused, and thinking about taking the truck on a road trip to the mountains, thought it would be nice to have the parking brake in good order.
