- May 28, 2015
- 12
I have a misfire that started on my way back from Tampa drove it about 60 miles with the misfire, got back and went to discount auto had the computer hooked up and was reading misfire cylinder #2, I replaced the coil pack and spark plug within the cylinder it seemed to help it a little, it doesn't idle as roughly and accelerates noticeably better but still idles rough and accelerates sluggishly I went back up and had them hook it again and got the same code, they said maybe it was a clogged injector. What should I do? buy a injector and see if that remedies the problem or maybe wait to see if it unclogs it's self I put some Marvel mystery oil in the gas hoping it may unclog itself, I cleaned the throttle body because I've had that cause rough idling before but nothing and I made sure to disconnect over 30 minutes to reset. Is it difficult replacing a single injector?
