P0171
mulletsrock101
5
Hi,
2006 TB 120,000 4.2 4x4
Trucks throwing light for code P0171. I see no difference in performance at all. Only notice MPG decreased. No loss of power. One thing to note is at idle (only in drive) i hear and feel vibration coming from passenger side front (glove box area) it immediately goes away if shifted in neutral or park or raising rpms. I think this is just a bad motor mount and no impact on P0171 .... thoughts on solutions ?
m.mcmillen
554
Wisconsin
For the lean code, I would check and make sure that your intake manifold bolts are tight. Over time, the rubber compresses and the bolts will loosen up a bit. Snug them all down (not too tight) and see if it helps.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
Take a look around the site, that is pretty common. Use P0171 site:gmtnation.com to search google, it will search this site.
timmerk
