- May 16, 2014
- 8
My wife's '04 4.2L I6 trailblazer has started setting the P0171 lean on bank 1 code. I am trying to determine if this is too much air or not enough fuel. I used my reader to clear the code and look at fuel trims at idle with the vehicle warm. The LTFT is solid at 8.2% and the STFT oscillates between +5% and -3%. The RPMS are around 600.
While driving, the code will be set and the RPMS will go to around 900 at idle and will not return to 600. If I clear the code, they will immediately drop back to 600 at idle. I also noticed that if at idle with the code cleared, when I turn on the AC compressor, the code will immediately be set and the RPMS jump to 900+.
Any advice on how to determine if this a lack of fuel issue or too much air issue?
