P0171 - Sigh, the story of my saga.
Grimor
954
CEL came on on the way home at a stop light. Got home, and idle is a bit rough. around 600rmp and dips randomly. Cleared the code and drove around a bit, no code till I got to a stop light and it popped on again. Gonna start diagnosing it tomorrow. Gonna log the O2 sensors and see if they are in synch or if one looks bad or out of wack.
My check list for problems is;
O2 Sensors
MAF Sensor
Vac Leak
Secondary Air Injection
Intake Manifold Gasket/manifold bolts
Or it might be one of those things that I won't see the CEL for a few more months. Anyone wanna buy a 2006 TB for $7k?
4,659
First thing I would do is check the intake manifold bolts. The bolts are 10MM and are easily accessed with a 1/4" drive socket, 3/8 drive is a tighter fit but works also.
Another suspect could be the MAP sensor but I would focus on the intake first.
How old are the O2 sensors?
Grimor
954
I've had the truck for about a month so no clue. From what I've heard (here) our trucks don't like Bosch so stick with AC Delco if I do end up replacing em.
I'll hit the manifold bolts tomorrow and see if I can snug em down a bit more.
4,659
Bosch O2 sensors are too hit or miss with these motors, definitely use AC.
These vehicles are very DIY friendly for the most part, don't lose hope this early. :thumbsup:
CaptainXL
If the intake manifold is leaking then there is dirt between the gasket, head and or manifold. The proper way to do this would be to replace the gasket, clean all surfaces and torque the bolts to spec in proper sequence.
Grimor
954
My record so far;
Curt Front hitch - Good
K&N HAI - Bad
Homelink & 12V ACC port - Good
Flat on rear - Bad
Red LED Interior - Good
Go Rhino Side Steps (returned because of bad powdercoat) - Bad
Hankook Tires - Good
Discount tire breaking spare tire cable - Bad
Lund Side steps (returned cause don't like em) - Bad
Husky Front and Rear mats - Neutral
It's a lot of bad for only the first month lol
4,659
Grimor said:
My record so far;
K&N HAI - Bad Not TB's fault
Flat on rear - Bad Not TB's fault
Go Rhino Side Steps (returned because of bad powdercoat) - Bad Not TB's fault
Discount tire breaking spare tire cable - Bad Jury is still out
Lund Side steps (returned cause don't like em) - Bad Not TB's fault
I know...lol But hope is not lost.
Denali n DOO
5,596
Grimor said:
My record so far;
K&N HAI - Bad
Flat on rear - Bad
I had a 0171 n 0174, cleaned MAF and throttle body and they went away...
4,659
Grimor said:
K&N HAI - Bad
Good eye there D-DOO...Me no likey K&N especially with a MAF sensor, could be coated in filter oil.
Grimor
954
Turns out the filter on my HAI wasn't even on. Kept wanting to pop off so I had to clean the oil off the rubber and slide the clamp higher.
Cleaned the MAF and we'll see what happens
jonu
