- Jul 22, 2015
- 2,724
Thought I was going to have to replace my p/s pump (after replacing hoses / gearbox and experiencing no assist at idle speeds even after bleeding; shop stated hydroboost was 'ok' and pump was to blame, when they were doing a wheel alignment today)
However, as I was later driving the old gearbox core to FedEx, and parking in their lot, I found the assist came back (for at least 2/3 of the steering wheel travel in each direction), along with the 'expected' noise from the pump as it's creating assist.
I'd like to think that (some of) the residual air finally bled out, anything left will eventually also bleed out, and I don't actually have to replace the pump (which isn't making unusual noises, and neither is the hydroboost module). Then there's a part of me that says this might be temporary, and the pump will 'fail' again. But I think (?) the pumps are fairly reliable, provided they don't run dry. I've never, ever had one fail in any vehicle I've owned, in my entire life (and that's a lot of vehicles, with several GM products in the list.)
Planning on taking the truck for an extended trip soon; I'll be 2000 mi. away from home & at the mercy of shops for any 'big' repair while on that trip (truck is otherwise reliable... knock on wood). I'll also be pulling a trailer, so I kinda need the full range of the power assist, not just the 2/3 or so that I have now. The brake assist was affected as well, as far as 'initial' engagement, but now also seem OK.
Did I dodge a bullet, or should I plan on replacing the pump? Thoughts?
(pump looks to be OEM; about 235K on it; it's in a HD pickup w/ the 6.0L gasser)
Also, FYI, the toe was way off, as I had replaced inner / outer tie rods (and also UBJs and the pitman & idler arms), so that might have affected things somewhat (binding?) But the drive back home from the alignment didn't seem to make the (lack of) assist any better... it was probably 30 miles and a couple of drive cycles later that the assist came back and started acting like normal.
