If you look at the object inside of the Yellow/Red Oval Highlighted in the attached image of the Symbolic Oil Flow Diagram for the GM 5.3L Engine... you can see that the Oil Pressure Sending Unit Sensor is the
Last Thing In The Oil Flow Line in the Vertical Column of the Oil Travel... situated at a "Dead End". So it is very likely that the Sensor itself is just Clogged ...as it has an in-dwelling Filter Screen Tube with a fine enough Stainless Steel Mesh to preclude that Steady Oil Pressure from ever reaching the Pressure Membrane (Piezo-Electric) if Clogged with Gunk and interrupting that trigger for the sensor signals to reach the PCM:
This is such a simple sensor in a way that its a damned shame it has to be positioned in such an out of the way place on this Motor. The attached Video can help you to get at it with the least amount of trouble. Use ONLY the
ACDelco OPS Filter and Sending Unit if you decide to R&R these components. You WILL need to obtain something like this
Lisle Model # 13250 OPSU Socket because Standard Deep Sockets will NOT work:
Available on Amazon for around $7.00 + S&H:
However... if you continue to see very sketchy oil pressure readings on your Instrument Cluster Panel... if the problem is NOT with the Oil Pressure Gauge on that panel itself, then a deeper investigation must be performed. This screen print from the OEM Service Manual shows you the Specialty Tools and Procedures necessary to follow to confirm reading the ACTUAL oil Pressure using an Analog Oil Pressure Gauge and make an accurate determination:
