So I am getting ready to attempt replacing all my rod bearings. This thread- <
tells me how to remove the oil pan (is it the same for my AWD 2006 Saab 9-7x?)
Are there any pictures anyone has that may help out or any advice? Manuals?
I can take pictures along my way and tell everyone if it works out or not if anyone is interested. When I remove the oil pan I will inspect it as well as check how bad the journals are before I go through with replacing the bearings. If this doesn't work, I'm not too worried, I will just buy a used engine online and swap it in.
Help removing oil pan, what am I doing wrong?
Stupid me thinking "there's nothing to it". Taking off the oil pan to look inside since there is low oil pressure when vehicle is warmed up and there is a light tapping sound (when warm). Oil pump replaced 20K ago. Figured I should look inside and peek at the bearings, see if oil pump screen...
gmtnation.com
