Oil Life Monitor Class 2 Data
NickInMN
3
Minnesota
I'm working on a device for my 1997 Hummer with an LBZ Duramax swapped in. I am using an Arduino and a VPW Transceiver from SwapSmart to access the Class 2 data bus. I have most of the class 2 data working but I'm struggling with one thing, the Oil Life Monitor and Fuel Filter Life. I have identified and can read the messages giving the value but every time I turn the vehicle off the values get set to 0. I've verified the ECM and TCM have power when the truck is off. I've even wired in a BCM and IPC but I get the same result. Does anyone know if there's some type of "handshake" needed with some module when resetting these? I have a VCX Nano and Tech2Win for resetting the values.
TJBaker57
3,052
Colorado
I can't say that I am following what you are doing there.
Are you reading the oil life as a PID from the ECM using a mode $22 message? Like "6C 10 F1 22 11 9F" ??
Or using Class 2 messaging? Like this one where the cluster requests the oil life remaining... "E9 4A 60 14".
Do you mean to say that the ECM itself appears to be losing the value when shut down? And it then reads 0% oil life remaining?
And exactly what ECM is used here?
NickInMN
3
Minnesota
When the truck is started the following message is sent 0xA8 0x4B 0x10 0x14 0x[XX] (this is oil life, fuel is behaving the same). 00 == 0 %, FF == 100%. I'm not requesting any data. I see this same message when I reset the oil life with my Tech2 clone as well. My ASSumption is that when the PCM has a new value for oil life it will send this message with the updated value.
I don't see any requests with 4A 60 in any of my logs.
Yes, the ECM appears to be losing the data when turned off. Or, it is requesting something at startup that it is not receiving a response to so it is clearing these out.
The ECM is a Bosch. This isn't a picture of my ECM but it is the same was what's in my truck. 1728077013070.png
Reactions: TJBaker57
8,144
Welcome to GMT Nation...
This is "The Dope" on that Bosch ECM Part# 12606127 ....with more particulars besides...and the idea that if it came the Wrong Calibration... weird Sensor Behaviors-Signals might occur:
Product Description
2006 Duramax equipped vehicles, LLY VIN code 2 (8th digit is “2”). Choose from refurbished A-Grade or B-Grade, as well as factory NEW. Note, B-grade is cosmetically flawed and may have a cracked or chipped receptacle that will not affect durability or function. All grades include applicable warranty when ordered with factory programming (add to cart separately).
GM Service Numbers 12606126, 12606127, 12603623, 12604137, 19260753, 12588335 are interchangeable.
O6 LLY/LBZ NOTE: The lower power rated 06 LLY preceded the 06 LBZ emission certification. The 06 LBZ engine included programming that is more refined and adds 30 HP and 60 ft-lb torque. The upgraded “Factory LBZ programming” is an available option in the drop down menu as a low cost upgrade to the factory program file. IMPORTANT: YOU MUST PURCHASE FACTORY PROGRAMMING to take advantage of this discounted +30HP LBZ upgrade offer.
PS...
Whenever time permits... Filling in "The Dope" on your Vehicle Profile will help us. Also... the ASCII Codes you posted may or may or may not decode in reference to THIS ASCII Chart:
  • ASCII_Characters.pdf
TJBaker57
3,052
Colorado
Ok, now I know how you are reading the data. That helps.
As far as I know your assumption is correct. I cannot say that your ECM does this but it seems logical. I know my 2002 P10 PCM does this updating of the value. And my 2005 Yukon also does it.
Both vehicles clusters occasionally request the data as well. Here is a snippet from my Yukon where the PCM broadcasts the value, then shortly afterwards the cluster requests the same and the PCM again broadcasts the value.
I have hundreds of logfiles for my two vehicles spanning several years so it is possible for me to catch things that aren't a normal occurrence. But this request from a cluster looks to happen fairly often.
I don't think I have ever reset oil life using a Tech 2. Both my vehicles have the DIC and I use the steering wheel buttons to reset. I would expect the Tech 2 to use a service $AE message to perform such a reset.
That said I just sent a load command to a benchtop test PCM I have here in the house and the PCM did as I instructed. I spoofed a message from the BCM telling the PCM to load the value $FF into the oil life parameter.
I'll need to do some tests to see if it remains there when in the key off state and then later if the battery power is disconnected.
I assume there is just one always on battery power to your PCM?
TJBaker57
3,052
Colorado
I looked for some examples of the PCM updating the oil life as it decreased. I discovered that the PCM does sometimes broadcast an oil life of $00 at startup but then jumps up later. I have yet to discover how this works....
In this example the vehicle was shut down and restarted minutes later more than once before the 14:45 timestamp where it sent the $00 value. A decrease is seen between 13:46 and 14:09.
TJBaker57
3,052
Colorado
I reviewed some of these files where the PCM sent an oil life monitor value of zero.
I see that in every case this only happened within a couple seconds of key ON. And in short order the PCM follows up with the real value. Often, the cluster requests the value right after the zero value is sent.
I analyzed one file in my spreadsheet that decodes all serial data traffic and there is no evidence of the value being stored or retrieved anywhere else but the PCM.
I am wondering if this zero value is sent only as some sort of display system initialization.
I see similar traffic for other display related data. For examples, as the key is turned on the BCM repeatedly sends messages to the display system to turn off the high beam indicator and security lamps among other warning or indicator lamps. This is done before the cluster is even displaying anything while the key is at ACC.
These BCM messages are generally acknowledged by the IPC whereas the oil life monitor messages are not.
More random data to float around upstairs.
NickInMN
3
Minnesota
Thanks for all your input. I haven't had a chance to test this but I think your data points me in the right direction. My code is currently looking for A8 4B 10 14 as the identifier for the oil life message. I think that's part of my problem, I'm assuming the priority part will always be the same which I now realize is a bad assumption. Hopefully I'll have some time this weekend to do more testing.
Are you just using spreadsheets and filtering for your screenshots? I'm just logging to text files right now and importing that into a spreadsheet. I was hoping to use the logger in Universal Patcher but I can't figure out a way to load an existing file.
TJBaker57
3,052
Colorado
I record my logs using am Android device and a free android bluetooth serial terminal app and a Veepeak Mini Bluetooth OBD2 adapter.
All my logs go into a folder on the Android. Many are far too large for a spreadsheet.
I use another older Android app (aGrep) to do a regular expression search of the logfiles. In this way I can quickly scan for messages meeting various criteria.
This is one of the RegEx expressions I used for the screenshots above.
..:..:...[0-9][0-9][0-9] .. 4[A-B] .. 14
This gives me anything addressed to either $4A or $4B with the secondary ID of $14.
If I find I want to further investigate a given logfile I cut/paste either the whole logfile if it is not too large or a snippet to get what I want to see into the spreadsheet.
The spreadsheet is a monster. I am no programmer so I'm sure this can be done better but this is what I am capable of and it works for me.
The spreadsheet (a Google Sheets doc) does some lookups from portions of the SAE J1850 specifications to make the reading/decoding easier.
Here is a small part of what the spreadsheet shows me....
Partially highlighted in light blue the PCM reports oil life of $00, the cluster requests same, and the PCM reports the real value of $47.
I have not seen the message priority vary for a given message except between vehicles perhaps. But in the case of oil life reports both my vehicles use the same priority.
chappymate
