[Google Translated]
Good afternoon to all the friends of GMTnation I turn to you in order to know what is the real measurement of the engine oil dipstick of a Trailblazer 2002 Vortec 4200 inline 6 engine. This is because my rod broke.
Thanks friends, I wrote in Spanish to see if it translates only
No, this site will not translate automatically so please translate before posting (like you had been doing before). I also translated the title.
The empty oil pan takes 7 quarts or 6.6L of oil. If your disptick broke in the tube, you will likely need to remove the entire dipstick to retrieve the remnants of it. If it's the plastic end that broke off, then it fell into the pan. I just hope that particular type of plastic doesn't float in oil or you might need to remove the pan to retrieve it if it doesn't come out with the oil.
When getting a replacement, I suggest getting one from a later year with the metal end instead of the plastic. It is sturdier and also easier to read.
