That sucks Marc, I hope everything works out.
Btw, what is your avatar? Looks almost like a flywheel from tapatalk.
Do they still get circulation?
you better!!mcsteven said:Got to make up for my....
Absence.
This will work. When I first got my HIDs, I had a 9006 relay running my fogs. Also, the fog light wiring is thicker than what's inside the headlights, so a relay harness isn't necessary. I currently run my fog HIDs directly off the stock 880 plugs to the ballasts, no issues for the past 2 years.Mounce said:I might possibly have a 9006 relay harness that I can use it for the fogs if the plugs were compatible. Fogs will get 880 HIDs if they get them. I feel like they are compatible since the HID ballasts have 9006/5 looking connectors and the 880 wire will plug into them.
It's been too hard with the kids here to repair the LEDs I soldered recently, if you guys recall. Sucks I've spent only about 2hrs of time on my TB the past month. Only 2 car washes....dmanns67 said:Speaking of lights, my passenger side Cree shutdown last night on my way home. Need to figure out if it if the driver or the LEDs![]()
I must not be a regular woman than because size doesn't matter its what you can do with itdmanns67 said:Ask any woman and they will tell you that size ALWAYS matters.
Mine will sit at 100% and say waiting for response. I have let it sit for 10 minutes before an nothing. I end up going to the mobile site on my phone to upload any pics. PITA.
Easiest way to test is to swap the left side driver to the right side.dmanns67 said:Speaking of lights, my passenger side Cree shutdown last night on my way home. Need to figure out if it if the driver or the LEDs![]()
Already done my friend.Darkrider_LS said:Easiest way to test is to swap the left side driver to the right side.
I have had them for around 2-3 weeks. They have a total of 2 hours of use. 10 minutes a day at most.Aarkon said:Dang man havent you only had these a week or two?
You cant make it to England in a row boatTBLS said:I must not be a regular woman than because size doesn't matter its what you can do with it![]()
Surprisingly enough, the drivers are ok. I guess the LEDs failed. OverheatedDarkrider_LS said:How did it turn out?
Thanks for the info Carlton.Blckshdw said:This will work. When I first got my HIDs, I had a 9006 relay running my fogs. Also, the fog light wiring is thicker than what's inside the headlights, so a relay harness isn't necessary. I currently run my fog HIDs directly off the stock 880 plugs to the ballasts, no issues for the past 2 years.![]()
That's what I call my Ex-girlfriends.Capote said:Women can be c***s
Auburn's gonna beat dat assBlazingTrails said:Good morning whores!!
Ga/auburn game at 7:30 eastern
