Hey all , well i have a misfire , again. my fault i think , i was stuck with no gas station around and was forced to drive about 20 miles with the light on.
i used the wifi veepeak v01 and dash command app and it wouldnt connect... i tried my regular scanner and got code p0300 right away , but need the app because i have all the gm pids to see each cylinder.
its not the app or wifi elm , i plugged it in the other car and it read it instantly.
im at loss , i found info on no obd2 , but it was due to a bad fuse and no power , i have power , both lighter ports work , and my innova scanner work.
there are only 4 wires in the obd port , power , ground and ?? all pins seem tight
any ideas on why i cant get a reading ?
