No... On "Cleaning" O2 Sensors...
Have a Look Here...
Ask your Friend
WHY he either wants to "Clean Them...or Replace Them". If he wants to replace them because he is getting "O2 Sensor Codes"... Tell him that the O2 Sensors are actually working properly when they report issues of incomplete combustion or "Left-Over O2". Explain that this is
precisely what they are meant to be doing.
Tell him that ordinary Oxygen Sensors use a Thin Slice of Cubic Zirconia held inside of a Protective Cage and they meter the Exhaust Stream while sampling for the presence of Oxygen that
SHOULD have been almost completely consumed (Burned) during the Internal Combustion Events occurring within each Engine Cylinder 4 Stroke Cycle.
If the O2 Sensors find a certain percentage left over in excess AFTER they enter Closed Loop... Then something is not right: Vacuum Leaks, Failing EFIs, Failing Fuel Pump Pressure... such things can all contribute to the presence having of
TOO Much Oxygen getting into the Engine Cylinders during combustion events and LEAN out the Fuel to Air Ratios.
These devices strictly measure the presence of Oxygen in EXCESS...
NOT Fuel in EXCESS. Tell him the 'One Up Front' measures for Excess O2 BEFORE the Exhaust Stream gets into the Catalytic Convert and that the OTHER O2 Sensor measures the presence of Oxygen left over AFTER the Catalytic Converter has supposedly Treated the Exhaust By-Products and "Cooked" them free of N2O and other Noxious Vapors. He needs to find out WHY these conditions exist due to those other causes and events being "Out of Whack".
